Newbie Minus Build
Becko
, Mar 05 2018 10:37 PM
11 replies to this topic
Posted 05 March 2018 - 10:37 PM
Just joined thought Id say hello
Hopefully Ill be starting my minus build soon
Early shell ( mk1 back end )
Ive had it for about a year now so need to make a start on it
Got an allspeed subframe with a 106 gti engine
Will post some pictures when I work out how to
Chris
Chris
Posted 05 March 2018 - 11:53 PM
Lucky lol i myself been looking for a shell, i will be following along. To post photo you click on choose file select the photo and then click on attach this file, if you use online photo hosting like flicker just post the link
Edited by Mini-dude, 05 March 2018 - 11:55 PM.
Posted 06 March 2018 - 08:07 AM
Does the 106 engine fit with the Bonnet shut? I have a Micra engine to go in my Minus, purely because it's the only conversion I've come across that lets the bonnet shut properly.
Post up lots of pics please!
Posted 06 March 2018 - 07:40 PM
Looking at the subframe and shell yes it’s going to be close,
If it doesn’t I’ll just sell the subframe/engine/ bike carbs
And choose a different engine
I do have a 16v bonnet which may give me little bit more room.
Still can’t find how to post pics
No file option that I can see
Posted 07 March 2018 - 07:09 AM
Think I cant add photos because of the new user restrictions
Posted 07 March 2018 - 05:24 PM
Hi and welcome.
Where did you get the shell?
Having a mk1 back end does not make it earlier. Its hard to distinguish a year comparing one shell to the next.
There are a few very early shells which had external door hinges 3-4 max.
Be interested to see your progress :).
If you haven't already joined, there is quite an active group on fb.
https://www.facebook...inus/?ref=br_rs
Posted 07 March 2018 - 10:32 PM
As soon as I can work out how to get the pictures on Ill post some
Progress.. hmmmmm
Ive been collecting parts but this year Ive decided I need to start it .
I bought the shell from down south , its new never been painted
Even the front inner wings and front end havent been bonded on , rear window opening needs trimming back
standard front windscreen fits but the rear is mk1
Small rear screen and quarter windows
Ive got really good standard doors which seems a shame to cut down to fit ( internal hinges )
Twin bolt front subframe fitting which is a pain as the allspeed subframe is the later single bolt type
Progress.. hmmmmm
Posted 07 March 2018 - 10:33 PM
Ill have ask the other half to join the Facebook group as I dont do fb
Posted 07 March 2018 - 10:38 PM
Found the picture link ..
I was using the mobile site ... doh !!!
Anyway
As you can see its tucked away in the corner of the garage awaiting my attention.
As soon as my tvr is back together Ill get some better pics
Chris
Anyway
Chris
Posted 11 March 2018 - 07:36 AM
Seen you have posted on the group.
Most of them are mk1 rear screen and quarters. You can cut it out larger, i wouldn't personally. mine had been previously though.
The shell was near me, the rollcage was bought off me by the last owner. I never used it and bought it modified of ebay.
Its easy enough to modify the shell to single bolt. Just drill through the centre and make up some spreader plates retaining the original crush tubes that are in the shell.
Posted 11 March 2018 - 08:14 AM
Got the other half to join the fb group 👍🏻
The shell has just been sat in my garage since I bought it whilst I gathered up bits for it.
Got a mk1 rear screen and quarter windows
Shell came with a mint set of doors which need modifying to fit
Cage is going to be extended ( front section and dash rail .. possibly tie into the subframe mounts )
Unsure what Im going to do with the front end
Bond the inner wings and front on or leave the front end removable
Posted 11 March 2018 - 08:18 AM
As for the crush tubes ... there is nothing in the bulkhead box section ( that I can see ) just the drill holes for the twin bolt setup
So Im either going to leave the subframe as it is ( single bolt ) and modify the shell or I have the tops off a twin bolt subframe which I can weld onto the allspeed one ( leave the shell as it is )
Either way Im going to be adding some spreader plates as the fibreglass just doesnt seem strong enough
