1973 850 was off the road but dry stored from about 2011.
Good A+ 998 fitted, original 848 unit available.( condition unknown)
This car is quite original, body was painted about 10 years ago but its still pretty tidy.
Its very standard in the way it looks, it drives as it should, seats re-trimmed in powder blue, black door and side cards, standard 10 wheels.
Body
Its had outer sills, a patch on the n/s front floor, and a small patch in the boot floor, all looks to have been done to a good standard probably around the same time as the repaint.
Theres a few bubbles under the paint on one A panel, the lower corners of the rear quarters and one wing, the other wing has been painted since the repaint and is not a perfect match.
Mechanics
I have done a lot of work !
*complete clutch hydraulics and linkage replaced
*wheel cylinders replaced
*rear shoes
* several brake pipes & front flexs pipes
*re sealed mcyl
*exhaust ( standard)
*engine serviced
* several hoses
* wiring sorted professionally new fuse box etc
*two new tyres
* waxolyd under and cavities
* greased
* wiper blades
* serviced wiper system
* H4 conversion
* sorted heater
pm me for a viewing. I will add some photos shortly
Car in South Woodham Ferrers Essex
