Dash Cam For Mk3/4's
7 replies to this topic
#1 eddy1000
eddy1000
    Starting My Mini Up
  • 2 posts
Posted 08 March 2018 - 10:07 PM
I am wondering if anyone is running a dash cam for their MK3 or 4 mini's? I've done hardwire dash cam installs on new cars with fuse boxes, but not with an older car like a mini.
Which wires should I tap into to get access to power when the car turns on?
#2 Ethel
  • 25,416 posts
Posted 08 March 2018 - 11:53 PM
If you're looking for an ignition fed, live they're the green wires after the fuse, white if unfused.
#3 minifreek1
minifreek1
  • 1,260 posts
  • Local Club: S.U.N.M.O.C
Posted 15 March 2018 - 08:02 AM
You could pick up a switched low current feed (which is all you'd need) from the back of the radio on the ISO connection. Usually the yellow wire...
#4 MasterD78
MasterD78
  • 125 posts
Posted 17 May 2018 - 06:11 PM
So I am curious if anyone is running a dash cam.  I've been debating it, but would love to hear if someone has any experience.  Following this thread for sure.
#5 timmy850
timmy850
  • 2,997 posts
  • Local Club: MITG
Posted 18 May 2018 - 10:55 AM
My tip is to always buy a high quality high speed memory card. The cheap ones can cause problems with freezing or re-starting
#6 MasterD78
MasterD78
  • 125 posts
Posted 18 May 2018 - 10:22 PM
Do you have one installed in your mini?  My main question would be running the wires.  Putting them under the headliner isn't a simple task like it is in modern cars.  Any thoughts?
#7 timmy850
timmy850
  • 2,997 posts
  • Local Club: MITG
Posted 18 May 2018 - 11:07 PM
I dont have one hard wired into my mini. Ive got one that plugs into the cigarette lighter accessory power so I can swap which car its in.
Could you possibly run some wires using the same path as the roof light? Of course getting to the headliner is a big deal in the later cars.
#8 Albino_Hedgehog
Albino_Hedgehog
  • 341 posts
  • Local Club: Solihull Mini Classic Club
Posted 19 May 2018 - 08:54 AM
In mine I have a hard wired USB port that the dash cam is then plugged into.
The wire for the cam is simply pushed into the corner between the a post and windscreen, up over the sunvisor and then to the dash cam on the mirror!
