Hundreds Of Spares Available
Posted 09 March 2018 - 08:11 AM
Radius arms for reconditioning,some might be ok others bare, £20 each
8.4" brake calipers, need recon, £3 each, YES, £3 each, about 30 available.
Diffs, you would need to check what ratios, were £40ea now £20 each.
Used rear spacered drums £2 ea
Front Drum hubs, front disk hubs £10 ea
Rear hubs, were £40 pr now £20pr
Gear linkages £10 each.
Quick shift gear linkage £25
Steering racks, i would advise need new gaitors and track rod ends, £10 each. About 15 available
Grills, various, chrome, steel standard etc, no mk1 or clubman at this price. £10 each will require some tidying up. 20+
Grill ends and bonnet chrome £1 each
Various door cards, might have some sets, £5 each. 40+
Rear seat sections, either back or base, £20 each.
Steering columns with keys £30 mk4 on. No mpi
Columns with no keys £15
Glass, rear heated screens only £5! Each. 30+ available. Side and door class £10 ea, mk4 on
Mk1 rear screens were £100 now £75ea
Mk2 clear rear screen £75
Mk1 piano hinge side windows £150 pr. 3 pairs available
Early mk3 clear opening rear glass £60pr getting very rare.
12" alloys, ideal for spare or trailer, £10 each. 2xrevolution, 1x 12" minilight,2xgb minilight
Rocker covers £5ea standard. Alloy finned £10 ea.
1275 12g940 heads, bare A+ £50 ea. A series £70ea
Twin bolt hydrolastic subframe with working units, bargain £200
Mpi front subframes £30 each
Used rubber donoughts £5 each, 50+ available
Alloy trumpets front or rear £5 each. 50+ available
Subframe tower bolts £10 pr
Various flywheels and clutches used. £10-£30
Flywheel housings £10 each, various ones
Clutch covers (wok) £10 each, or £5 if bought with flywheel housing.
Heaters, metal £5 each, plastic £10 each. Class as spares or repair. Some work fine.
Spi used rear exhaust from cat back. Good useable condition £10.
Rough side exit large bore back box £5
Switches used, hazard headlight etc £2 each.
Switch panels £5 each 30+ available
Blue boot lining kit £15.
Red and black boot lining kit with base box and kenwood speaker £15 bargain.
Window regulators £10 each
Bargain carpets £5 set, will need a clean and will be useable.
Chrome interior door handle sets £10, not perfect hence price. Plastic sets also £10.
Door weather strips inner and outer £5 each.
Smooth boot lid, steel, £20.
Doors for reskinning/repair from £10
Number plate lamps £5 each, including chrome,various colours.
Headlinning bars £5 each £20 set.
Bars and headcloth £30
Various wheel trims, hub caps £5 each.
Demister vents £15 pr
Eyeball vents £20 pr,
Bulkhead vents £20 pr
Air intake on inner wing, spi and normal (not clubman) £10 each.
Seat brakets £10 set (4)
MG metro front seats, ideal for mini require frames made suitable for retrim, £40pr 2 pair available £60 for both pairs
Metro gta red/black seats with very close match mini rear seats, bolt in to mini, £100
Mini 30 half leather interior, requires tidy, with door cards, bargain, £150
Loads of alloys available, call for details. This is a tiny selection of what i have available
Posted 09 March 2018 - 11:05 AM
any brown carpet? I need the sections that cover the flitch panels
Posted 09 March 2018 - 04:09 PM
have u got any body shells forsale floor condition and bulk head doesent matter there for racing don't need v5 eather thanks
Posted 22 March 2018 - 08:21 AM
Ive got some bits but not for over the arches. If i come accross any i will let you know
Nothing in at the moment
Posted 22 March 2018 - 10:31 AM
Hi, do you have a decent 10" wheel with tyre (steel or alloy) for use as a spare?
Posted 25 March 2018 - 05:44 AM
Posted 26 March 2018 - 09:19 PM
Posted 01 April 2018 - 02:51 PM
square inner sill grommets from the later cars?
Posted 02 April 2018 - 06:09 AM
I will have, im constanly sorting through boxes of stuff and when i come accross them i will let you know. Be in garage all day again.
Keith
Posted 02 April 2018 - 06:12 AM
Have a 10" steel and almost like new tyre. £30. But not sure what postage would be. But less than a tenner.
Posted 02 April 2018 - 05:23 PM
Posted 02 April 2018 - 06:38 PM
Do you have a MK2 lower dash rail cover in original black vinyl?
Posted 03 April 2018 - 12:20 PM
