Seized Bolt Front Brake Cylinder
brakes
7 replies to this topic
#1 goat64
goat64
  • 24 posts
Posted 09 March 2018 - 12:53 PM
Hi all
Went to change cylinder on my 1976 850cc mini, to be thwarted by the smaller or the 2 bolts securing it to the back plate.
None of my spanners seem to fit snugly.
A 5/16" is too tight, and a 9mm is too loose.
I think the bolt should be a "1/4 inch UNF 3/8 long" (part number on minispares is SH604031), but a 1/4" hex spanner is way too small.
It's a bit corroded, and I expect to spend a while with some WD40 and some gentle tapping to free it, but do't dare be too "forceful" unless I have a really good fit on spanner.
Anyone confirm what size hex / ring spanner I should be using?
Any other tips to get it out?
The larger bolt has come out fine.
I guess I can always change the whole backplate with offending cylinder still bolted on, but it seems a bit excessive for 1 stuck small bolt.
Thanks in advance
Goat
(1976 mini 850 saloon - with twin slave cylinders on each front wheel. The offending bolt is on the trailing cylinder)
#2 nicklouse
  • 17,944 posts
Posted 09 March 2018 - 12:59 PM
put the WD40 down and find some release agent like PlusGas.
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 09 March 2018 - 02:10 PM
Do what the men say for a few days I lkie 3in1 oil and or plusgas but wd40 smells best to me
Edited by ukcooper, 09 March 2018 - 02:11 PM.
#4 ings
ings
  • 178 posts
Posted 09 March 2018 - 03:01 PM
heat the bolt up with a heatgun...
#5 nicklouse
  • 17,944 posts
size for the 1/4 UNF should be 3/8 AF IIRC
#6 richmondclassicsnorthwales
  • 942 posts
Posted 09 March 2018 - 04:59 PM
I stock these, so when your done removing, if you want replacements give me a shout - PM me
We only charge  £1.20 p & p. no vat,  small bolt + washer 45p  larger 90p + washer
Regards Neil.
#7 Spider
  • 13,923 posts
Posted 09 March 2018 - 06:54 PM
Not sure if it was the same in the UK, but our were something oddball like 7/32" AF.
#8 goat64
goat64
  • 24 posts
Posted 10 March 2018 - 08:17 AM
SOLVED:
Hi guys
Thanks for all the advice - helpful as usual.
In the end, found a 2-BA hex socket was a perfect fit. Not sure how this matches up to 7/32" and it certainly didn't fit a 3/8" socket. I found out a 2BA is 8.25mm, and doesn't map to any AF size.  This site is the source:
http://www.baconsdoz...sion charts.htm
Stupidly, I had made a note of this after hours of fiddling around when I changed the other side cylinder 4 years ago.
It is pretty tragic when you get to the stage of not being able to remember what spanner to use after hours of struggling, so you write it down for next time to save hassle, then you forget that you've written it down !!!!    Just off to write myself a note to check the note I made last time if I ever need to change the darn thing again.
Thanks to Neil for offer of new bolt, but despite my best efforts to to damage the head, it seems perfectly servicable still - will bear it mind for next time.
Cheers again
Goat
Also tagged with one or more of these keywords: brakes
