Hole In Gearbox
Neuraminidaze
, Mar 13 2018 11:33 AM
64 replies to this topic
#61
Posted 15 March 2018 - 10:45 PM
What id attempt to do is start the engine on the floor before its plumbed into the car unless you can verify the mileage
#62
Posted 16 March 2018 - 12:13 AM
Not easy to do with an MPi, in fact Id say it would be easier to drop in and test compared to trying to cobble together a test rig.
#63
Posted 16 March 2018 - 09:33 AM
Get the reg no of the written off Mini and check the MoT history here https://www.check-mot.service.gov.uk/
That will tell you if it is 20k or 120k.
#64
Posted 16 March 2018 - 10:28 AM
Not easy to do with an MPi, in fact Id say it would be easier to drop in and test compared to trying to cobble together a test rig.What id attempt to do is start the engine on the floor before its plumbed into the car unless you can verify the mileage
And wouldnt tell you anything other than maybe cold oil pressure.
Could easily do a compression test and leakdown test though. Although they might not tell anything with gummed up rings from sitting that long.
Does the UK mot keep mileage records since day 1? Very little cars only do 20k in 20 years
#65
Posted 16 March 2018 - 10:34 AM
It may not tell you it's only done 20K but if it's done more you'll definitely see it.
