Is the Starter and Altenator from a 998cc the same as 1275 cc or are they bigger for the 1275?
Starter Motor And Altenator
Jc1991
, Mar 13 2018 02:12 PM
3 replies to this topic
Posted 13 March 2018 - 02:12 PM
Posted 13 March 2018 - 02:40 PM
Aslong as it's both pre engaged or both inertia starters they can be used on both engine sizes.
Alternator will also work on either engine, you want to make sure you have enough amps to power the electrical items and charge the battery
Posted 13 March 2018 - 04:58 PM
Thanks, just wanted to make sure there wasnt a difference in cranking power
Posted 13 March 2018 - 07:33 PM
With a 1275 it's worth fitting the largest battery which fits in the battery box, this helps when starting particularly in cold weather.
