Mini Trailer
Posted 16 March 2018 - 07:46 PM
Any help much appreciated
Jerry
Posted 16 March 2018 - 08:08 PM
you mean using the entire front end - subframe included - or grafting the front panel-wings-bonnet-bulkhead over the rear subframe assembly (..which would make more sense from a capacity perspective..) ?
Posted 16 March 2018 - 08:29 PM
Posted 16 March 2018 - 09:43 PM
Posted 16 March 2018 - 10:12 PM
Edited by jelboy89, 16 March 2018 - 11:04 PM.
Posted 16 March 2018 - 10:13 PM
Front end would look better made into a BBQ!
It's a common thing now thou. It's either a trailer or a wall mount with speakers
Posted 16 March 2018 - 11:28 PM
I think if you did it, it would be best with it facing backwards, mount some round taillights in the headlight holes.
as for keeping the front subframe in, it would make a very heavy trailer for a mini to pull, personally I would make a lightweight steel box section frame and mount proper indespension units under it, make a flat steel floor to fit inside it all too. much lighter and compact and you would maximise the internal space too.
Posted 17 March 2018 - 11:19 AM
Posted 17 March 2018 - 02:05 PM
That's the way I ment. Could build a frame but weight isn't really an issueI think if you did it, it would be best with it facing backwards, mount some round taillights in the headlight holes.
Edited by jelboy89, 17 March 2018 - 03:21 PM.
Posted 17 March 2018 - 04:01 PM
Weight is an issue if you want to tow it with a Mini and be able to carry anything in it. Sounds like a lot of work, lots of sharp edges that don't line up to make a neat closure. Has to be easier to start from scratch and incorporate a grp flip front.
Posted 18 March 2018 - 12:59 AM
