Spi Alarm/immobilizer Won't Disengage
Best Answer rossul.burn , 20 March 2018 - 07:12 PM
I disconnect the horn tonight (loosened off the ECU bracket) and got in the car with all doors shut and pressed the button 4 times to resync it which worked. Car started up fine with no issues
Go to the full post#1
Posted 18 March 2018 - 02:58 PM
The next time I connect the battery the alarm keeps going off. Nothing will stop it, I've tried the key fob and don't hear the usual click. I really don't want to annoy my neighbours but this is doing my head in. Can someone help me with this?
And my new bloody exhaust doesn't fit. How typical.
Posted 18 March 2018 - 03:16 PM
if standard look in the foam behind the airbox and there should be 3 inline fuses clean em up or replace them as ones for the alarm,
Posted 18 March 2018 - 03:19 PM
Posted 18 March 2018 - 04:55 PM
standard fuse box or 24
24 fuse box, no inline fuses. I've checked the fuses that are marked for the alarm but they are all okay
I will put car in profile now
Posted 18 March 2018 - 05:41 PM
could it be that I have to resync the fob by pressing unlock four times seen as i have had the battery disconnected?
Posted 18 March 2018 - 07:22 PM
Replace the battery in the fob for starters and disconnect the horn so you don't upset the neighbors
If the alarm was armed when you disconnected the battery, the alarm will be armed when you reconnect the battery. If the alarm is disarmed when you disconnect the battery, the alarm will be disarmed when you reconnect the battery. You need to re sync the fobs when you have disconnected the battery.
Posted 18 March 2018 - 07:26 PM
daft question but how do i disconnect the horn?
Thanks for the advice
Posted 18 March 2018 - 08:26 PM
just unplug it
Posted 19 March 2018 - 05:10 PM
just unplug it
Sorry this should have been worded differently.
How do you get to the plug? The ECU is in the way and there doesnt seem to be enough cable to move it out the way and disconnect the horn, if i did disconnect the ECU would this cause problems?
Posted 19 March 2018 - 08:49 PM
Posted 19 March 2018 - 09:34 PM
Posted 20 March 2018 - 07:12 PM Best Answer
