Thanks all. I checked the numbers and indeed it is 21A1684 struts that causes the height.
Anyone has the struts of a saloon available ?
Best Answer timmy850 , 19 March 2018 - 02:43 AM
It might also be that the front is too low if the cones are old and compressed. What is the ride height like at the front end?
My car is at about 8-10 cm at the back between the top of the tyre and bottom of the guard. The cars sat pretty high from the factory
Go to the full postPosted 19 March 2018 - 08:02 AM
Posted 19 March 2018 - 08:09 AM
So what year is your car? As some have mentioned above they might be correct for a post 1984 car with 12" wheels
http://www.minispare...ic/21A1684.aspx
https://www.minimani...mmpet-Rear-Late
Posted 19 March 2018 - 08:17 AM
Thanks, you are right it is a 1988 car so should be correct then ?
It also says in the text ' If you had the suspension lowered by cutting the trumpets and you want to restore to the standard ride height and appearance, these alloy trumpets make it possible
So it is known that the car at the rear is above standard ride height and can be adjusted by adjusting (cutting ?) the trumpets or buy HILO set ?
Posted 19 March 2018 - 08:24 AM
Posted 19 March 2018 - 09:46 AM
Will do thanks all for support. Niels
Posted 19 March 2018 - 10:16 AM
Posted 19 March 2018 - 11:13 AM
and the are correct for your car.
fit and let it settle.
Posted 19 March 2018 - 11:16 AM
Posted 19 March 2018 - 07:14 PM
Factory low mileage 1995 car, I've painted them satin black but the number is clearly visible.
As I recall, by then they were fitted. I think it was in fact 1988 was the C/P.
It wasn't to do with the 12" wheels - the 1275GT had those from circa 1974 and on Saloon Trumpets.
Posted 19 March 2018 - 07:17 PM
but the GT had a spacer added between the knuckle and trumpet.
Posted 19 March 2018 - 07:43 PM
Not from the factory (listing published in 1981 after the 1275 GT had finished production so covered them all)
Posted 19 March 2018 - 10:21 PM
