Hi Everyone
I have a std/std CAM 6232 crank for my GTM engine, my question is, is it ok to regrind to +10 on a race engine? as I have to use 1 1/4" SU's I can't see it revving much past 7000 rpm. I read somewhere that a 10 thou regrind has a negligible affect on the strength, is that true? Also on the same theme, is a centre strap necessary on a A+ block?
Ta
S
For Competition Engines I've always ground the cranks - even new ones.
When having it ground, asked for it to be Indexed (or corrected depending on their terminology) and Phased. Some Cranks are very good here and some are way out. In regards to size, if you are looking to get every last 1/10th HP from the engine, I used to have the pins ground to -0.040" on the smaller journal sizes.
Indexing it will correct the stroke of each Crank Pin and Phasing it will ensure that the Crank Pins are exactly 00 and 1800 (as applicable) to each other.
I would have all the spinning parts balanced and I would advocate against a centre main strap or any fancy steel cap - these engine just don't need them.
If you are contemplating wedging the crank, have that does before any of the grinding operations. I would suggest it it a good idea here, not just to lighten the crank but - if done right - extend it's life.
