Fitting A Oil Pressure Warning Light
Posted 20 March 2018 - 03:46 PM
Would this work? https://www.demon-tw...re-gagelite-kit
Thanks.
Posted 20 March 2018 - 04:15 PM
Any alterations from standard?
If it's an A series engine you need the proper fitting, then it's just a wire to the light and an earth.
Edited by cal844, 20 March 2018 - 04:17 PM.
Posted 20 March 2018 - 04:25 PM
that will be fine and as a kit is a fair price. go for the 20psi one.
Posted 20 March 2018 - 04:42 PM
It's an a series yes, was unsure whether the kit would fit into the block
Posted 20 March 2018 - 04:48 PM
Cheers.
I have no experience with the one you linked, Nicklouse said it will work, just make sure the light comes on at around 20 psi
Posted 20 March 2018 - 05:04 PM
If you're going to the effort, wouldn't a proper gauge be better?
Edited by r3k1355, 20 March 2018 - 05:04 PM.
Posted 20 March 2018 - 05:08 PM
Posted 20 March 2018 - 05:19 PM
Cheers.
the only thing I cant comment about is the T piece.
but have a look at
http://www.minispare...spx?1~2~26|Back to catalogue
and this for thread info
http://www.theminifo...ake-off-thread/
Posted 20 March 2018 - 05:48 PM
It's 1/8npt so It'll screw right in, will need a T piece as above.
