HI guys! I want to know the gap used in an engine that is H/C
Also would like to buy some new spark plugs
Agustin
Posted 25 March 2018 - 02:14 PM
Agustin
Posted 25 March 2018 - 02:51 PM
Posted 25 March 2018 - 03:00 PM
same gap as standard. unless the plug makers states differently.
Also what do you mean by High compression?
Posted 25 March 2018 - 04:35 PM
Posted 25 March 2018 - 04:57 PM
BP6ES standard gap
Posted 25 March 2018 - 05:03 PM
Agustin
Has it got electronic ignition?
How many cc's ?
Is it a standard engine? or modified?
Posted 27 March 2018 - 12:11 PM
Atm I don´t know my engine compression and will be the next step to see on my car. I am running too rich with a single hs4 and really dont know the problem.
High Compression was 160lb when I once had done it
Posted 27 March 2018 - 12:12 PM
Agustin
How many cc's ?
It does have an electronic 123 ignition, don´t know the cv´s, it is a 1310cc with some work done, it pulls easy 145km/h on the freeway, Max top speed 162 km/h gps
Posted 27 March 2018 - 08:18 PM
Posted 27 March 2018 - 09:41 PM
When I had my MED 1380 set up on the rolling road by Peter Baldwin I was advised to run standard BP6ES and standard gaps if using a normal electronic ignition system. He said only open up the gaps if using a megajolt type setup.
Thanks a lot for the advice, so I will use champion N9Yc or NGK BP6ES
Posted 27 March 2018 - 10:22 PM
You should find the NGK BP6ES will be better.
Electronic ignition is not as fussy about plug gaps, 0.035" should be fine.
What makes you say it running rich ?
Posted 28 March 2018 - 04:59 PM
This allows me to say it is far too rich
Posted 28 March 2018 - 06:11 PM
If it is running really rich then possible issues on HS4 are:
- main jet not returning fully up when choke pushed in
- float chamber needle jet not sealing off
- incorrect main jet level
- worn needle (swing type)
- incorrect or modified needle
- badly clogged air filter
Posted 28 March 2018 - 06:23 PM
hard to tell as you cant see the important bits. need to see the sparking end and the ceramic.
that is just a picture of a dirty spark plug. Sorry.
Posted 28 March 2018 - 10:18 PM
I can check it out again if you want to, and also was thinking of buying some new ones, but would like to do some twerking on my carb to get it perfect
