Leak Problem
engine
10 replies to this topic
#1 jol0ng
jol0ng
    Starting My Mini Up
  • 2 posts
Posted 27 March 2018 - 12:01 PM
I have had my mini away in the garage and put a tray under it to see if i had any leaks. This is what i found. the leak looks like its coming from the gear box (not the oil, the coolant) (well i think it is) i'm not very good with cars lol. Anyone know where the leak would be coming from and how to stop it?
Thank you
#2 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 27 March 2018 - 12:36 PM
What type of engine is it? As the engine is above the gearbox, coolant will leak down the outside of the box. Which side of the car is leaking? Is the engine a runner? You need to thoroughly clean the engine and box off and then start it up and see where the leak is coming from rather than where it's ending up.
#3 slidehammer
slidehammer
  • 1,081 posts
  • Local Club: LSMOC
Posted 27 March 2018 - 01:02 PM
Classic Mini's are notorious for leaking oil. Depends how long the try was under the car, but that wouldn't bother me. You can replace all the seals and gaskets, but it won't long before you start getting drops of oil on the garage floor again. Just keep and eye on it and the oil level on the dipstick.
#4 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 27 March 2018 - 01:29 PM
I think he's asking about the coolant leak, not the oil. Everyone knows the oil is good for keeping the rust at bay. :proud:
#5 Dusky
Dusky
  • 5,322 posts
Posted 27 March 2018 - 04:05 PM
Unless it's an auto and it's ATF.
The gearbox is the whole bottom of the engine, so quite impossible for us to guess where it could be. You'll have to take a torch and take a look under the bonnet ;)
#6 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 27 March 2018 - 04:19 PM
You don't use ATF in the auto.
#7 Dusky
Dusky
  • 5,322 posts
Posted 27 March 2018 - 06:38 PM
Brain fart  :tumble:
#8 phillrulz
phillrulz
  • 617 posts
Posted 27 March 2018 - 10:20 PM
The oil drips at the back is probably the rod change oil leak, easy to identify clean the oil off the rod change and see if it appears again. Cooling wise. Id like to hope radiator bottom hose.
Plus guys, am i right in saying pink antifreeze shouldn't be used unless its a new ally radiator? Old soldered brass radiators require blue antifreeze? Which arnt compatible with each other?
Someone confirm or deny before changing?
#9 imack
imack
  • 1,873 posts
Posted 28 March 2018 - 05:33 AM
Stick with blue anti freeze, its safe with brass or alloy rads.
Pinks ok with alloy but corrodes solder in brass.
#10 jol0ng
jol0ng
    Starting My Mini Up
  • 2 posts
Posted 28 March 2018 - 09:16 AM
Cheers for the info guys, its a 998 1987 mini city, manual and the coolant leak is coming from the opposite side to the rad (driver side). Also the engine runs (just in storage atm)
Edited by jol0ng, 28 March 2018 - 09:17 AM.
#11 Northernpower
Northernpower
    Mr. 7-Port
  • 2,409 posts
  • Name: Graham
Posted 28 March 2018 - 11:39 AM
Clean it off and have a look at where it's tracking from; just because its finishing up at the flywheel end doesn't mean its starting there. Has it got the heater take off on the head if so is that ok?
