1D3461F3-2667-44A9-A541-6D99FEF48789.jpeg 28.99K 6 downloads
Edited by leewaa, 29 March 2018 - 08:01 PM.
Posted 29 March 2018 - 07:58 PM
Posted 29 March 2018 - 08:00 PM
Posted 29 March 2018 - 08:08 PM
I know it's probably obvious but have you double checked there is no shims on the crank? I was fitting mine and couldn't see the shims on the crank.
whats the end float on the cam? have you put a new triangle plate for holding the cam in? and whats the thickness of it, It may be a little thin.
you'd have to skim the difference off on a mill or lathe.
Posted 29 March 2018 - 08:13 PM
When checking, 'thrust' the Cam in to the Thrust Plate, ie, push the Cam towards the front of the engine.
If it's ground correctly, when running, it will naturally thrust this way and won't 'sit' any other way.
Posted 29 March 2018 - 08:39 PM
Posted 29 March 2018 - 08:41 PM
Its a fresh build so no existing shims on the crank, so new cam, new triangle plate. Unfortunately I dont have access to a mil or lathe.
Got my hopes up there, but unfortunately the camshaft is still sitting as far forwad as possible and there’s still a small difference.
I am using the timing cover from retrosport so this could be the cause.
are you using the gasket they supplied?
Posted 29 March 2018 - 08:49 PM
are you using the gasket they supplied?Its a fresh build so no existing shims on the crank, so new cam, new triangle plate. Unfortunately I dont have access to a mil or lathe.
Posted 29 March 2018 - 08:51 PM
Posted 29 March 2018 - 09:42 PM
Oh wait a minute
The gasket currently fitted seems thicker than the DSN one from what I can remember. While I was in the garage I thought that the thicker gasket is the issue but actually I need the gasket to be thicker. Either that or a thicker locating plate maybe. Though I will check it all again in the morning to suss some things out.
Posted 29 March 2018 - 09:55 PM
yes the gasket thickness effects the cam cog position. remember to torque the nut down on the cog to make sure it is all seated correctly (well it just needs to be tight so everything is where it needs to be).
to be honest i am slightly disappointed that DSN have decided that you need to use a non standard gasket when they could have easily made the cam thrust plate mounting at the correct distance....
Posted 29 March 2018 - 10:07 PM
Yeah makes sense now that I am able to think about it in piece and quiet was a long and frustrating day in the garage today.
The cam thrust plate I have is from Minispares. The gasket from DSN is currently out of stock too...
Posted 29 March 2018 - 10:11 PM
It may have been an oversight when they designed the covers as it would seem that many don't realise how important the gasket thickness is when it comes to timing gear alignments. The easiest fix is to have some thicker gaskets cut, but it does mean that you have to buy your gaskets from them.
I suppose you could use the standard gasket and use shim washers under the thrust plate instead.
Actually I was thinking about some shim washers under the locating plate too however I am not sure if this is ok ?
Its off by approx. 5 thou...
Posted 30 March 2018 - 07:50 AM
