Hi there!!!
I live in Vancouver Canada and recently got a 1992 rover mini 1.3 spi auto. Its from Japan and whoever had it before me took it off the road for 10 years and left it outside 😞 I got a great deal on it because of that.
It was running rough so I just did the valve seals, head gasket and a new crank angle sensor. Anyways its running pretty good now but the gas pedal still sputters. Its alot better now ( maybe the new sensor helped? ) but when gas pedal is pushed more than around a third of the way down the rpm shoots way down and car jolts a bit. I take my foot off the pedal and push down just a little bit again and its all good. I can keep driving when it happens, does not stall. Also car idles very nice, but when i push the pedal down too far as it idles same thing happens. Also when I have been driving past maybe 60kpm and it has happened a little bit of smoke does come out of bonnet. Im thinking its overheating a bit too. And no my temp gauge does not work 😞
I know there is ALOT of info on here about the injection system amd the breathers and vacuum lines and gas lines. I have read some of it and its great. THANK YOU! I am just wondering if someone can tell me the best place to start as I am new to this working on my car stuff. I have never done this stuff but I did valve seals and head gasket just fine so Im not totally clueless.
Thank alot guys! This seems like a great forum.
Cheers from Canada!
1 reply to this topic
Also tagged with one or more of these keywords: engine, electrical
Mini Technical Sections →
Problems, Questions and Technical →
Piston Rings - A-Series 998 Engine - Help RequiredStarted by WanaGo , 18 Apr 2024 engine |
Exhaust Choice 45Dcoe - Rc40?Started by lachlan1275gt , 13 Apr 2024 engine |
1071 Main Bearing Caps.Started by 246jaenick , 02 Apr 2024 engine |
Misfire - Ignition Fault Or Fuel Problem?Started by derekaka2sheds , 01 Apr 2024 electrical, engine |
Which Rocker ArmsStarted by mark the diver , 30 Mar 2024 engine |
