Hi all,
I'm having a spot of bother removing my cylinder head from my mini (1275 engine).
All nuts have been removed, exhaust and carb manifold removed, all disconnections made, however the head is "stuck on". Any suggestions?
(PS I have tapped the head with a rubber mallet to gently persuade, but this has not worked)
For further info, I am removing the cylinder head to replace the valve stem oil seals.
The engine is in the car.
thanks
