Mini Spares Gearbox To Block Bolt Kit
Posted 02 April 2018 - 04:58 PM
Screenshot_20180402-175142.png 189.52K 1 downloads
Posted 02 April 2018 - 05:47 PM
Posted 02 April 2018 - 06:47 PM
There's one short bolt on the front up the water pump end, however that kit will be 2 short bolts short if you don't have the studs.
The long bolt goes through the hollow dowel at the flywheel end on the back.
Posted 05 April 2018 - 11:22 AM
That kinda annoys me off a bit. I collected them from minispares stating I want the studs too and I was told they are all bolts now, the bolts have replaced the 2 studs. I've dry fixed the bolck and gearbox together befor I start throwing sealant everywhere, just to test and so far I have fitted the row of 5 at the front (middle length bolts) and 5 at the back (short) ok, but i have 2 bolts left! The long one and the middle length one. to be honest the middle one is long enough for the hollow dowl. What goes either side of the 1/2 moon seal?
gearbox.jpg 40.95K 0 downloads gearbox5.jpg 51.16K 0 downloads gearbox6.jpg 44.93K 0 downloads gearbox4.jpg 33.29K 0 downloads gearbox2.jpg 45.68K 1 downloads
Edited by Moke Spider, 05 April 2018 - 07:02 PM.
Posted 05 April 2018 - 07:06 PM
Hmmm,,,,
The length of the bolts that will fit there are the same as those used across the back of the gearbox.
I just buy my bolts in bulk rather than kits. Off hand, I think I use 1-1/4" length across the front and 1" across the back and either side of the 1/2 moon. I also use Spring and Plain Washers too.
Posted 05 April 2018 - 07:11 PM
2015-05-12 21.15.53(2).jpg 35.66K 34 downloads 2015-05-12 21.15.43(2).jpg 35.85K 29 downloads
Posted 18 April 2018 - 08:48 PM
Found this. Quite handy.
I have to give you a big thanks for these pictures. I could not figure out for the life of me where I took those two studs out of and where the 1" bolt went. Must be a pre A plus things.
So Thanks thanks thanks
Edited by Syma, 18 April 2018 - 08:49 PM.
