Gearbox Ratio
Best Answer Spider , 07 April 2018 - 08:40 AM
It'll likely have a 3.44, however Chris, be aware, they are a poor gearbox case, the centre web breaks easy.
Go to the full post#1
Posted 07 April 2018 - 06:08 AM
Posted 07 April 2018 - 06:46 AM
depends what it was fitted too
Posted 07 April 2018 - 07:00 AM
Yeah I’m not to sure.
Posted 07 April 2018 - 08:40 AM Best Answer
Posted 07 April 2018 - 09:00 AM
Thanks Moke, I only wanted it for the final drive.It'll likely have a 3.44, however Chris, be aware, they are a poor gearbox case, the centre web breaks easy.
Looks like it won’t suit my requirements.
Posted 07 April 2018 - 09:10 AM
What ratio are you after ?
Posted 07 April 2018 - 09:30 AM
2.9:1
Posted 07 April 2018 - 06:30 PM
2.9-1 has terrible pinion wear
Posted 07 April 2018 - 07:35 PM
Is this because of the ratio? Too much drive pressure being put on it due to the longer gearing????2.9-1 has terrible pinion wear
Have you experienced this yourself?
Posted 07 April 2018 - 09:41 PM
I don't think the genuine ones gave any trouble, but I know many aftermarket ones do.
Posted 08 April 2018 - 08:22 AM
yes i have experienced this its to do with gear loading and angles n stuff, ended up with a 2.76 with a two ring gear set in my car, because all my 2.9's were worn heavy.
