Differential Shimming
Best Answer Ethel , 08 April 2018 - 06:22 PM
The gap is equal to the required preload so you need a shim of equal thickness to the compressed gasket.
Minimans,
the gap allows the cover to fit closer (preload), the gasket holds it further away so subtract 4thou from 12thou and it's as if you had an 8thou gasket. You'd need a shim to add back the 4 thou preload 8+4 = 12.
gap + shim = preload + gasket
Go to the full post#16
Posted 10 April 2018 - 11:11 AM
#17
Posted 10 April 2018 - 08:08 PM
Why would it be on the packaging? It's a catalogue bearing. What I mean by that is it is a generic bearing from the RHP catalogue, it could be used in any number of different machines other than a Mini gearbox
To be fair, the late royal blue Haynes book is rubbish. The older sky blue one is much better, and it has both pre-load settings listed and describes the difference in bearings, You cant really blame Rover, Minispares or the Haynes manual, or anyone else really. Rover no longer exists and the reason why the thrust type bearing no longer exists. The next best thing is a catalogue bearing that Minispares and others stock (and incidentally Minispares have highlighted the difference, has anyone else?). The people behind Haynes are not in the parts Business and only go off the last factory data to generate their books (auto data is the same) so differences do creep in when obsolete parts are superseded beyond their control. Basically happens.
#18
Posted 11 April 2018 - 07:36 AM
#19
Posted 08 May 2018 - 08:49 PM
I'm a bit late to this party but thought would join in anyway.
I was struggling to get my head around the shimming maths for the diffs, sorry none of the above explanations of it helped, probably made me more perplexed! the haynes helped a little, but only when I started drawing diagrams (call me stupid) did it fall into place.
So I came up with another way of working it out(hopefully nice and simple), which amounts to the same sums as other people, but if this way helped me it might help others and help others get their head around it.
If you have a compressed gasket of .012 and when cover is on the gap is .004(where the gasket sits).
Simply subtract .012 - .004=.008 and all you need to do then is think this is the gap between the bearing and the cover that pushes up against the bearing.
So if you have a gap of .008 and if you add .008 of shims no gap no preload, so .009 give you .001 preload, .010 gives .002 preload so on until required preload acheived.
Just to demonstrate again with different gap same gasket size, gap .002 - gasket.012= .010 gap next to bearing, add the preload amount onto gap next to bearing, shim it up .014 for preload of .004.
Just to throw something else into the mix as well, anyone ideas on these taper diff bearings for coopers? what would preload be on these?
http://www.shop4auto...taper-diff-pin/
#20
Posted 08 May 2018 - 09:20 PM
Ok quoting myself now(I have lost it), just realised what I have wrote is exactly the same as ethal's maths, what through me was the opening statment "need shim of equal thickness of compressed gasket", which wouldn't always be the case only in that example, plus I was still scratching my head! But once you get your head around it, it all makes sense even what over people have written.
Edited by country clubman, 08 May 2018 - 09:25 PM.
