Spi Hesitancy Problem
14 replies to this topic
#1 MR J
MR J
  • 416 posts
  • Local Club: Doncaster Mini Owners
Posted 11 April 2018 - 06:45 PM
Hi
For about the last 4 years I've had a hesitancy problem with my 94 Spi sprite. Cruising at around 60mph it sometimes hesitates and won't accelerate, lifting off usually cures it and it will accelerate smoothly again.
I have so far replaced all the ignition HT system, lambda sensor, coolant temp sensor, throttle position sensor, cat and 88 deg thermostat but it is still the same.
I have invested in the Mems diag app and hooked it up to my phone and taken it for a run. I have attached some screen shots of the results of driving at about 60mph.
Should the fuel trim reading flat line? As when it flat lines that's where the hesitant problem occurs and what would cause this?
Edited by MR J, 11 April 2018 - 06:47 PM.
#2 MR J
MR J
  • 416 posts
Posted 11 April 2018 - 08:52 PM
It seems the fuel trim flat lines when it drops to 100, also the map sensor stops at 100 although I think that's it's maximum.
#3 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 12 April 2018 - 05:58 AM
Can you show a graph with TPS (throttle position) instead of battery voltage?......
#4 genpop
genpop
  • 473 posts
Posted 12 April 2018 - 06:12 AM
can you export your logfile? You have to be admin on your android then you can send the logfile.Then Sprocket  may be able to help!
#5 MR J
MR J
  • 416 posts
Posted 12 April 2018 - 07:52 AM
I figured out after the run I could add extra trends. Will have another run tonight and post details.
It's one of the reasons I replaced the TPS, although the one I replaced the original one with is used also.
#6 MR J
MR J
  • 416 posts
Posted 13 April 2018 - 02:10 PM
Think I may be slowly tracing my problem. I've borrowed another ecu just to eliminate mine and been for another run but I have simiĺar results.
Only this time the fuel trim is pretty stuck at 100% all the time and it seems to not change over to closed loop.
I had a fiddle with the lambda sensor connection and it jumped into closed loop and the fuel trim then started responding. It ran fine for a few minutes then dropped out again but fiddling with the lambda connection again makes no difference.
#7 MR J
MR J
  • 416 posts
Posted 13 April 2018 - 02:11 PM
#8 MR J
MR J
  • 416 posts
Posted 13 April 2018 - 03:15 PM
Think I may have found the culprit. If it is I can't believe I'd never looked at changing it.
#9 MR J
MR J
  • 416 posts
Posted 13 April 2018 - 07:29 PM
Maybe not, still having problems with it switching in and out of closed loop.
#10 genpop
genpop
  • 473 posts
Posted 13 April 2018 - 07:34 PM
why don't you publish the logfile
#11 MR J
MR J
  • 416 posts
Posted 14 April 2018 - 05:06 AM
I don't know how to
#12 MR J
MR J
  • 416 posts
Posted 14 April 2018 - 12:30 PM
Here's a few more screen shots if anyone interested
Running fine one minute, stuck in open loop the next.
These are all at idle and sat revving
#13 MR J
MR J
  • 416 posts
Posted 14 April 2018 - 04:07 PM
Would the experts say this is a dodgy lambda sensor?
Just sat idling
Edited by MR J, 14 April 2018 - 04:08 PM.
#14 genpop
genpop
  • 473 posts
Posted 14 April 2018 - 06:31 PM
I don't know how to
on the three dots in right upper corner you may set the preferencies for mems diag.There you can set a prefix for log-files.Type for example mini-log. After return you can start the log by toggle log.Here you may stop it too.
Then you need a file manager on your android.There are some for free in the play store. Or you have one already. Search in main memory .directory  mems-diag will be found.There is your log-file. Send it to your email adress. Open mail on pc and publish it.If you have microsoft excel, you may import it as .txt file and have a look to the values yourself.
#15 MR J
MR J
  • 416 posts
Posted 25 April 2018 - 08:51 PM
Replaced the 2 year old lambda sensor with my 24 year old Bosch one and car is now running great.
Took for MOT today and sailed through emissions without a problem
