Posted 12 April 2018 - 08:11 AM
I recently took my mini in for a free brake check to make sure everything was still in working order as theyve faded quite a bit.
Any how, I picked my car up from the garage and it had literally NO brakes. I stood and argued with them for at least an hour as they were saying it was like that when it came in and I know it bloody well wasnt as I wouldnt have driven it with NO brakes. Anyway they put it back up on ththe ramps and discovered the from drums havent been adjusted. After doing this, I had some brakes but basically have to put my foot to the floor to get the smallest amount of braking. I couldnt be bothered to spend any more time there arguing with them so I left.
Does anyone know what could be causing this problem? Is it possible theyve left something undone?
- I have the smallest amount of pressure when the brakes are at the floor
- if I pump 2 or 3 times the peddal gets stiffer but as soon as it released it goes back (this doesnt work when driving)
- Handbrake still works perfectly
(Ive got 10/5.5 weller wheels and a full set of drum brakes)
Any and all help is hugely appreciated.
C
Posted 12 April 2018 - 08:13 AM
Posted 12 April 2018 - 08:25 AM
Posted 12 April 2018 - 09:37 AM
I had a lot of bother with my wife's drum brake mini last year, I must have spent almost two weeks trying to bleed air out of it. Turned out it just needed the drums adjusting a bit more
Posted 12 April 2018 - 12:17 PM
That may be what is wrong with mine. Just bled all the air, topped up brake fluid. Much improved but still not right. Im going to have a browse through TMF and see if I can find out the correct brake adjustments and how to make them- will keep you posted!
Separate issue but its developed a fault where if I break too suddenly it stalls even with clutch down- any ideas?
Thanks again!
C
Posted 13 April 2018 - 12:15 AM
Posted 13 April 2018 - 12:27 AM
The drum adjustment front and back makes a huge difference when done properly.
As Dusky says, turn the front adjusters in the direction the wheels spin.
Posted 13 April 2018 - 05:12 AM
Posted 13 April 2018 - 05:47 AM
Before bleeding turn the brake adjusters so that the drums are locked. Bleed by keeping brake cylinder full at all times - good system is pipe on the nipple and other end into jar with abit of fluid. Need two people to do this. Open nipple slightly and push brake pedal slowly to floor and hold there; close nipple and slowly release brake pedal. Do this at each wheel until all air is out.
Considering the age of your mini the master cylinder might need an overhaul and also check the pedal to master cylinder clevis pin for wear.
Once hard re adjust brakes until has slight resistance when turning.
It would seem that most owners ignore changing brake fluid every 2 years because of the hassle.
Good luck
Forget to mention that it is far easier to do job with the car on stands with all four wheels off.
Edited by Rorf, 13 April 2018 - 05:48 AM.
Posted 13 April 2018 - 11:27 AM
Merv
Posted 13 April 2018 - 12:32 PM
AgreedIt's been in for a brake check so they will have stood on the pedal pretty hard several times. My guess is you have a leaky cylinder in one of the front drums and the test has finished it off
Merv
Posted 22 April 2018 - 09:16 PM
Turned out to be adjusters on the front shoes, it appear the garage completely messed them up (front and back)
Went through the rigmarole of adjusting them back and now my brakes work perfectly
Thanks for all the advice
C
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Adjusting Brake Bias For 7.5" Discs With Pdwa ValveStarted by Daniel Watkin , 16 Nov 2023 brakes |
Answered
Fam7821 Brake Limiter Valve - Mounted Upside Down?Started by tarnofsky , 29 Sep 2023 brakes |
Kent 286 Can & MotStarted by frosty90 , 07 Sep 2023 brakes |
Brake Master Cylinder ReplacementStarted by M I N I , 30 Aug 2023 brakes |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
