Interesting Block I Just Brought
19 replies to this topic
#16 grizzler73
grizzler73
  • 300 posts
Posted 16 April 2018 - 05:30 PM
Thanks Nick,
From that thread, Mokespider wrote:
There were 3 series in the 1275 block castings pre-A+ that I know of and I'm quite sure, this is one of them.
The early series were thin flange. These are a fairly rare. These were also machine up to take the smaller big end crank, which were thinner across the thrust faces, though it's likely that the last of them were wider, but I'm not 100% sure on this.
Later ones (not long after those ^) were basically the same, but thick flange.
The last of them were similar again to these ^ but the tell tale being an added lump to the casting for the later tensioner type timing chain set up. From the blocks I've had my hands on over the years, these were generally the best of any 1275, A+ included.
Mine has that added lump.
Rorf, what do you mean? Elaborate please.
#17 Rorf
Rorf
  • 859 posts
Posted 17 April 2018 - 05:11 PM
To be honest I would not use that block - far too much rust on the internals.
#18 28hodge
28hodge
  • 223 posts
Posted 17 April 2018 - 06:04 PM
I got quoted £150 a bore for new liners about 2 weeks ago so didn't buy the engine I was looking at as it makes more sense to pay more for a block on std/1 size overbore.
Only reason I can see in spending the money to re line an engine is if you have an car with original engine that's ruined and you are wanting to maintain its heritage
#19 grizzler73
grizzler73
  • 300 posts
Posted 17 April 2018 - 06:32 PM
I know it looks bad but it is cleaning up rather well, a bit of a go with a rotary wire brush does wonders!
#20 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 20 April 2018 - 01:15 PM
Hi Chap's
Wondering if you can help, I just got a 11 stud 12G 1279 block off eBay, it has a lot of surface rust and still had the cam fitted. It is stamped on the sprocket end KC MD 276 SB and has a star drive type oil pump, is that Kent 276? Also would this be a good base for my race engine?
Hate to say it, but is that not a block with the hole above the centre main...?
If so, its too risky for a race block even with the hole polished
