What Boost/vacuum Pipe Are People Using.
Posted 16 April 2018 - 07:44 PM
Posted 16 April 2018 - 08:30 PM
as theres not really any fuel/ oil in the line you can get away with the silicone stuff ok, somthing ive seen used is the ptfe line and fittings that is used for welding gas, pnumatics etc.
https://www.ebay.co....umatic&_sacat=0
Posted 17 April 2018 - 07:36 AM
Posted 17 April 2018 - 08:03 AM
It's only what's connected downstream of the carb's jet you need to worry about, and then only if they flow enough to ingest petrol vapour - what's the volume of a MAP sensor or boost gauge
Posted 17 April 2018 - 08:22 AM
I've always used 3mm ID vac hose. Never in all the years i've had it on my cars has it ever caused an issue.
Posted 17 April 2018 - 11:54 AM
Sod it. I've just been using silicone boost/vacuum pipe too. I'm just getting less gun ho and actually started reading things before I buy them.
Posted 17 April 2018 - 11:55 AM
yep, mines downstream
