Engine Steady Bulkhead Heavy Duty Bracket
5 replies to this topic
#1 Gillybobs
Gillybobs
  • 237 posts
Posted 16 April 2018 - 08:04 PM
Just seen Smiffys bits are selling a thicker gauge bulkhead engine steady bracket .
https://www.ebay.co....W-/183152124279
The one on my mini needs replacing. Has anyone fitted one of these ones or is it overkill for a standard mini?
#2 nicklouse
  • 11,749 posts
Posted 16 April 2018 - 09:34 PM
well if you need one there is nothing wrong with it.
#3 lawrence
lawrence
  • 1,327 posts
Posted 16 April 2018 - 10:28 PM
That's nearly £8 for a piece of bent steel and some holes. If you want a stronger one just make one yourself :)
#4 cal844
cal844
  • 6,228 posts
  • Local Club: www.scottishmini.net
Posted 17 April 2018 - 11:34 AM
That's exactly what we did, used a section of steel 4x4 fence post, cut and drilled to suit then welded up solid
#5 Gillybobs
Gillybobs
  • 237 posts
Posted 17 April 2018 - 08:32 PM
Doesn't seem that much money to me . Half price of a heritage one.
It wouldn't be worth the hassle to me for that sort of money as I've no metal to make one out of and no template either.
So back to my original question has anyone fitted one yet?
#6 cal844
cal844
  • 6,228 posts
Posted 17 April 2018 - 08:55 PM
No but I have fitted a DIY copy of the above, basically we used a standard thickness one for the shape and hole position, then welded in place with a couple small strengthener pieces to reduce flex.
Mini Spares
