ok, so i now have in my possession a nice ACR4 and leads/pods
still having the cutting out issue so i ran it up last night and when the car was about up to temp it just cut out... dead stop... also it was 'kettling' through the small hose to the expansion tank. i guess that would indicate the stat was open lol... also for reference, the stat, CTS, CTS Fly lead and expansion cap are all new
i got fault codes as follows (after clearing some i found, CTS one mainly)
02 - Coolant temperature sensor circuit, Logged, sensor output voltage too low
05 - Sensor supply circuit, logged, sensor output voltage too low
13 - Fuel pump relay or purge valve or MIL lamp or communications circuit, logged, ECM ouput circuits
so, it appears that fault )" came back when it cut out, and they all appear to be regarding low voltage... so anyone in the know got any ideas?
am i looking at a bad earth or something more sinister?
would a high temp cut the engine dead?
is there a way of snapshotting the data on the ACR4? i see it has a pc connection port?
as it is, although the car is running well when it does, i cant take it out for fear of it cutting out and not restarting
please help
Edited by Honda-Mini, 07 October 2019 - 10:32 AM.
