Exhaust Pipe Cracking At Converter?
9 replies to this topic
#1 Darwinism
Darwinism
  • 92 posts
Posted 17 April 2018 - 04:51 PM
Hi,
Hopefully someone can clear up some confusion, I noticed my exhaust was catching, when I looked underneath I saw it was dipping in the middle just past the heat shield towards the front end, there's no mounts there so on closer inspection I noticed the weld between the pipe and what I'm guessing is the centre silencer????? is splitting, there's a flange a few inches further toward the front, just before the converter so my hope is that I don't have to go near the manifold and can buy a replacement but the options confuse the heck out of me, it seems, if the links below are correct that a replacement pipe from the converter back, are a tonne more for a mpi than any other model, is that right?
The car is a '99 mpi.
is this the right part?
https://www.moss-eur...ml?assoc=154785
or these, argh I'm so confused, there's a massive price difference
https://www.moss-eur...ml?assoc=154768
http://www.minispare...px|Back to shop
Edited by Darwinism, 17 April 2018 - 06:42 PM.
#2 paul748
paul748
  • Just Joined
  • 80 posts
Posted 17 April 2018 - 06:34 PM
Hi
I would say you need the more expensive one.
The cheaper one is for the earlier non cat mini.
#3 Darwinism
Darwinism
  • 92 posts
Posted 17 April 2018 - 06:46 PM
How about the mini spares one?
#4 FlyingScot
FlyingScot
  • 2,660 posts
Posted 17 April 2018 - 07:11 PM
For standard for MPi this http://www.minispare...t/GEX33519.aspx
On the page there are better flowing alternatives quoted too if you want something a bit noisier.
FS
#5 Darwinism
Darwinism
  • 92 posts
Posted 17 April 2018 - 08:26 PM
Thanks for that link FS, very helpful, I missed that one completely.
I'm thinking of replacing it myself, it only looks like 2 mounts and 2 bolts, which I can cut if necessary, do you think it's a manageable job for a novice? How does the pipe from the silencer fit into the cat, does it just slide in, or is some sort of adhesive needed?
Edited by Darwinism, 17 April 2018 - 08:35 PM.
#6 paul748
paul748
  • Just Joined
  • 80 posts
Posted 17 April 2018 - 08:48 PM
Sorry, I missed that one when I replied to your post.
Yes, that one :D
#7 brivinci
brivinci
  • 1,101 posts
Posted 17 April 2018 - 08:50 PM
I can recommend Maniflow products. I've had 2 over the last 15 years...and only bought a second as I went from a single box to a twin box. Wonderful product.
#8 Darwinism
Darwinism
  • 92 posts
Posted 17 April 2018 - 09:05 PM
Cheers.
Was it easy to fit? How exactly does the silencer pipe fit into the cat?
#9 brivinci
brivinci
  • 1,101 posts
Posted 18 April 2018 - 02:35 PM
You just unbolt from the cat and the entire rear section of the exhaust, what is sometimes referred to as a CAT-Back system can be removed as a unit. The rear section is hung by rubber hangers.
#10 Darwinism
Darwinism
  • 92 posts
Posted 18 April 2018 - 02:40 PM
Thanks very much, I think I'll give this a go myself, going for the rc40 unit.
