Wiring A 65D Distributor After Replacing A 59D
Posted 18 April 2018 - 07:09 PM
Posted 19 April 2018 - 08:47 PM
Ok I think I've sussed out the above, now I previously removed the ballast resister wire but didn't disconnect the yellow and white wire from the starter solenoid, can this wire be removed as I now have a permanent 12 volt feed from the fuse box?
Posted 19 April 2018 - 09:55 PM
disconnect the yellow /white wire, no longer needed. Did you remove the ballast resistor from the loom?
Posted 20 April 2018 - 09:23 AM
Posted 20 April 2018 - 12:37 PM
