Wheel Play
11 replies to this topic
#1 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 18 April 2018 - 07:29 PM
Evening TMF,
I've got some play in my drivers front wheel, and want some advice on what it could be please! I fitted a new wheel bearing, this made no difference, track rod ends are brand new, I've checked the balljoints, I'm not 100% sure but when I tightened them so that they couldn't move there was still play (will redo this). Any ideas :wacko: , got MOT coming up soon!
VIDEO : 40833368554_a533180c94_c.jpgUntitled by Will Giddings, on Flickr
#2 nicklouse
  • 17,945 posts
Posted 18 April 2018 - 07:33 PM
12 and 6 ball joints, 3 and 9 track rod end and or steering rack loose. all around the clock Wheel bearing.
#3 Spider
  • 13,934 posts
Posted 19 April 2018 - 05:20 AM
That'll be either steering rack, steering rod end or a loose steering arm,
Or a combination of these.
#4 minimissions
minimissions
  • 3,427 posts
  • Local Club: M.M.O.C
Posted 19 April 2018 - 05:42 AM
This is exactly what I have wrong with my car, it has a new bearing and that seems to be ok for a few miles then its coming back again so much so that I have brake wobble... its doing my bloody head in!
#5 GraemeC
GraemeC
  • 7,315 posts
Posted 19 April 2018 - 05:45 AM
Probably worn hub, drive flange or conical washer.
#6 minimissions
minimissions
  • 3,427 posts
Posted 19 April 2018 - 05:48 AM
Drive flange is brand new, I will try the washer..
Thanks Graeme c
#7 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 19 April 2018 - 05:57 AM
Il throw my hat in the ring and say the hub
#8 minimans
minimans
  • 411 posts
Posted 19 April 2018 - 06:30 AM
I could guess all day long but I won't strip it and take a look.......................................
#9 Will16
Will16
  • 1,090 posts
Posted 19 April 2018 - 08:55 AM
Thanks guys, didnt think to have a look at the steering rack, track rod end is brand new but rack and track rods themselves are ancient, if that doesnt solve it Ill try a new hub
Not sure what this comments about? If you read the post youll see I have stripped it down and replaced the bearing and track rod end and its made no difference, Im asking what else its likely to be, keep your narky comments to yourself 😴
#10 MacGyver
MacGyver
  • 1,027 posts
Posted 19 April 2018 - 08:59 AM
Sometimes the inner plastic bush wears out(specially the passenger side) and then the rack is loose.
Turn fully to one side, grab the track rod and shake it all about... 🙄
Or hold it and have someone wobble the steering and feel for play.
Happened to me once and took me a week to figure this out... 😂
#11 GraemeC
GraemeC
  • 7,315 posts
Posted 19 April 2018 - 09:14 AM
I would certainly suspect steering rack.
With that much play it should be pretty obvious where the problem lies to be honest, but the phone video is too shaky to see what is and isn't moving.
In fact, with that much play you could probably take the wheel off and waggle the brake disc - would give you a better view.
#12 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 19 April 2018 - 09:45 AM
Steering rack wear, best removed and reconditioned
