Tuning Dual Carbs Question
5 replies to this topic
#1 mergedown
mergedown
  • 17 posts
Posted 20 April 2018 - 12:57 PM
I posted a question a while back and received an amazing response outlining the steps to help me adjust the mixture on my carbs. I had assumed it was running a little rich, but now Im not sure.
I understand that when you push on the lifting pin and it increases and stays increased...its too rich. If it increases and then almost dies...its too weak. Mine definitely decreased on one carb, but doesnt increase at all. The other would cause the engine to die almost immediately with still no increase. I made some adjustments and the motor doesnt seem to die, but still cant get it to replicate what its supposed to do. Do I just need to keep adjusting?
#2 Retroman
Retroman
  • 967 posts
  • Local Club: CDMC
Posted 20 April 2018 - 01:31 PM
You need to check that at fast idle they are both drawing the same air....before adjusting the mixture
Its a bit if a faff but with the air cleaners of and some hose....
Listen to each carb to make sure each has the same noise, the hose has to be in the exact same place on each carb mouth.
Its then a case of adjusting the idle screws so both carbs sound the same.
Then the mixture can be set accurately at a fast idle.
Then turn each idle screw back the same amount to set the idle
All of the above assumes there is no linkage affect from the choke, and nothing binding or sticking
You sometimes find the legs on the linkage need adjusting
#3 mini_man96
mini_man96
  • 81 posts
Posted 20 April 2018 - 04:30 PM
A Gunsons colourtune and carb balancer will make the process a lot easier aswell!
#4 Spider
  • 13,934 posts
Posted 20 April 2018 - 06:44 PM
As they do seem to be running well lean, check you haven't got a vacuum leak too and this could even come from the carb spindle bushes.
#5 mergedown
mergedown
  • 17 posts
Posted 21 April 2018 - 12:46 PM
Thanks everyone! For some reason I’m intimidated by this process as I’m afraid I’ll mess up the tuning and it won’t run the same. That said, I’ve received a lot of great info, so I’m just gonna go for it! Worst case, I’ve got some great resources in our local Mini club, so I’ll reach out to them if I get stuck.
Thanks!
#6 gazza82
gazza82
  • 2,919 posts
  • Local Club: TMF+
Posted 21 April 2018 - 05:13 PM
I tried a carb balancer on an MGB and gave up after a while. When for the 'listen through a tube' method in the end. (I'm convinced the balancer was faulty)
