Advice Before Tomorrows Exhaust Change, With Pic
18 replies to this topic
#1 Darwinism
Darwinism
  • 92 posts
Posted 20 April 2018 - 05:52 PM
Hello,
Changing the exhaust from the cat back tomorrow. A few question as I really don't have a clue.
The bolts are rusted to buggery, is that area safe to apply a heat torch if I can't get the bolt out???
Looking at the flange it's already separating, do you think it best to cut the bolts down the middle???
The cat flange gasket, does it matter which way around it goes???
http://www.minispare...19.aspx|Back to
Cheers.
#2 GraemeC
GraemeC
  • 7,315 posts
Posted 20 April 2018 - 06:23 PM
Cut and replace the bolts, you'll have a fair fight with those.
If you're replacing cat back you probably won't need that gasket - it looks like yours is a ball & socket type joint, I'd just use a smear of exhaust past one the mating faces,
#3 Darwinism
Darwinism
  • 92 posts
Posted 20 April 2018 - 06:31 PM
Cheer for the reply.
How about the heat?
#4 KTS
KTS
  • 2,272 posts
Posted 20 April 2018 - 06:56 PM
i wouldn't bother - you'll just end up burning the paint of the floor (inside & out) and would still have a fight with the bolts anyway
don't think you'd be wanting to reuse the bolts even if you could get them off, so save yourself a lot of time and effort and cut them off
#5 Darwinism
Darwinism
  • 92 posts
Posted 20 April 2018 - 08:05 PM
Great cheers for the advice.
#6 Darwinism
Darwinism
  • 92 posts
Posted 21 April 2018 - 06:09 PM
Failed miserably, cut the bolt to get the pipe off easy enough but I couldn't for the life of me get what remains of the bolt head and thread seperated from the cat flange, I spent hours cutting, grinding, smashing and drilling to no avail (stayed clear of heat as advised). Started it up as I was curious what it would sound like without silencers, horrible! I need to get it to a garage where they can get better leverage and some air powered tools on it.
My final question on this one, will the car (mpi) be ok to drive just over a mile to the garage with the exhaust ending at the cat?
Cheers folks.
#7 spraybeater
spraybeater
  • 468 posts
  • Local Club: Mcr
Posted 21 April 2018 - 06:33 PM
Cheers folks.
Have sent you a PM re exhaust
#8 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 22 April 2018 - 09:43 AM
Unfortunately the cat itself has studs at each end, not bolts.
You'll have to drill out what remains of the studs and replace with bolts instead
#9 Darwinism
Darwinism
  • 92 posts
Posted 23 April 2018 - 05:03 PM
Hello,
Is the car safe to drive 1 mile to the garage with the exhaust ending at the cat?
#10 cal844
cal844
  • 9,488 posts
  • Local Club: TFMOC
Posted 23 April 2018 - 06:53 PM
Hello,
No, get the car recovered, or tow it there with a friend
#11 ings
ings
  • 178 posts
Posted 24 April 2018 - 10:26 AM
Is there a big hole next to your exhaust?
#12 Darwinism
Darwinism
  • 92 posts
Posted 24 April 2018 - 04:06 PM
Hello,
Can someone explain why not, what harm does it do? Cheers.
#13 Darwinism
Darwinism
  • 92 posts
Posted 24 April 2018 - 04:07 PM
Yes, it's the heat shield though, not the floor.
#14 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 24 April 2018 - 05:37 PM
Hello,
Thatll be fine! Its only a mile, myself (and Im sure many others :lol: ) have driven with just the lcb manifold after a speed bump removed the rest
#15 Darwinism
Darwinism
  • 92 posts
Posted 24 April 2018 - 06:17 PM
Hello,
Hmm this was my thought, after all it's only the silencers that are missing. Any other opinions, does it make a difference been a mpi?
