Hi guys,
Ive just had to fit a new choke cable and I cannot for the life of me get the bracket for the switch plate back through the left passenger side...any tips?? The hours spent on one bolt 😂😂
Fitting Switch Plate
MISSMADFORMOTORS
, Apr 21 2018 11:05 AM
3 replies to this topic
Posted 21 April 2018 - 11:05 AM
Posted 21 April 2018 - 12:30 PM
Hi guys,
You may need to bend the bracket or cut some foam away etc
Posted 21 April 2018 - 04:52 PM
Yip one needs to be a contortionist with elf fingers to get that nut back on. Helps to remove the front seats so one can lie on ones back, or use a small mirror to see whats going on.
Posted 21 April 2018 - 05:03 PM
I must admit I don't have a lot of trouble with this, make sure the stud is through the hole, use a 1/4 Drive socket and short extension, I use my left hand to do the right one and my right hand to do the left, the left is more of a git, but not that much agro, just sit in the drivers seat and lean over, un hook the heater to give you more room.
Shooter
Shooter
