Rotten Relay Box
4 replies to this topic
#1 nomoreheroes
nomoreheroes
  • 22 posts
Posted 22 April 2018 - 02:25 PM
Hello,
I've been having a dig around after my persistent non-firing up problems. This is the insides of my YWB10022 relay box.
This isn't a good thing is it? I presume it's a critical failure?
What does this line do?
I can't refurb it can I? I'll need a new one?
Elliott.
#2 ukcooper
ukcooper
  • 1,625 posts
Posted 22 April 2018 - 02:34 PM
right for one you need to put what year and model your mini is in you profile or at least your post
so I'm guessing it a http://bullmotifmini..._relay_ywb10022
#3 ukcooper
ukcooper
  • 1,625 posts
Posted 22 April 2018 - 02:38 PM
http://www.theminifo...-functionality/
#4 genpop
genpop
  • 474 posts
Posted 22 April 2018 - 06:00 PM
wash the corrosion away with wd40 or simular.Then take a volt(ohm)meter and check all the conductor path.If everything is ok you could clean everything with brake cleaner and then isolate with clear color spray. I do not think this is your problem.
#5 nomoreheroes
nomoreheroes
  • 22 posts
Posted 22 April 2018 - 06:09 PM
The resistance on the track is negligable. I traced the track to the resistor between the main and starter relay.
Elliott.
