Hi all,
AM in the process of rebuilding the front end and have a few simple questions...
On a 92 sprite...
What should the bonnet safety catch land on or latch on? At the moment its making a mess of the e-coat on the front panel upper surface. I can find these but it says MPI only?
Is there something similar for carbed minis?
Secondly there are three holes in the hinge brackets on the bulkhead. Are these used to change the alignment of the bonnet or am I only supposed to use one particular hole for the hinge bolt on each side?
Thanks in advance all
Jon
