i love your wheel/tyre damper setup! perfect color and size.
But with this wheels you should go with a full adjustable suspension!
Lower arms/Tie bars/hilo everithing should be adjustet and the car drives 100 times better.
Oherwise it will pull in every direction and in wet conditions very dangerous.
Thank you, I was quite relieved that the color combo worked as well as it did. The green is a bit tricky.
I am inclined to agree with this assessment and I'll likely order these parts up. I suppose I wouldn't be so eager to get this back on the road if it hasn't been off the road for so long now.
That's it but I don't think you'll need that many cuts, the fold itself should create enough strength I think although a few mig weld tacks wouldn't hurt at a later date.
The trouble with the idea of just raising the car is just moving the problem along, the maximum travel possible will be when the upper bump stop is compressed, if you hit a big bump on a right hand bend and you have just a few mm too much arch left it will ruin the tyre at best, ruin you and the car at worst.
Good, then I think I've got the concept and I'm also glad it won't require that many cuts.
I do understand what you're saying and I'll work on trying to put the car through a better range of motion. I definitely don't want to revisit this anytime soon or at least not until a more complete restoration is to be performed.
Edited by Kombi, 25 April 2018 - 02:21 AM.
