Electric Window Kit.
Posted 23 April 2018 - 09:19 AM
A proper one that replaces the manual wonders, not a cheap and nasty make shift kit.
Thanks in advance
Posted 30 April 2018 - 08:47 AM
Posted 05 May 2018 - 07:33 AM
I have a kit I have just removed from a project to go back to standard. Nothing wrong with the kit I just wanted it to be original as it came from an Italian job. All there but will need the wiring replaced as it was cut from the car before I got it. Wiring is simple enough though. Wiring is there for the switches just need to join the drivers side and passengers side and add a power and earth.
Could you grab some photos?
How much are you asking?
Thsnks
Posted 07 May 2018 - 07:44 AM
Posted 08 May 2018 - 05:10 AM
Ill grab a photo today for you
Top man 👍
Posted 08 May 2018 - 02:42 PM
Posted 12 May 2018 - 03:12 PM
Edited by screech, 27 May 2018 - 08:44 PM.
Posted 27 May 2018 - 08:43 PM
Up, still looking ?
Posted 17 June 2018 - 05:47 PM
Up, still looking
Are you still looking ?
Posted 17 June 2018 - 06:24 PM
Posted 17 June 2018 - 06:53 PM
I thought you had these ‘in stock’ according to your replies on other threads?
Just noticed that after you have pointed it out ???
Posted 17 June 2018 - 07:25 PM
That’s right, I do have these in stock after having trouble with my supplier, but I am also in the market for second hand units for some experimental purposes.
Edited by screech, 17 June 2018 - 07:34 PM.
Posted 19 June 2018 - 08:26 PM
Posted 21 June 2018 - 10:07 PM
Still have my set if you wanted to make an offer
What kind of kit is it please? The type that uses the original winder mechanism or the type that has its own lift mechanism.
