The Best 10" Brake Setup?
brakes
8 replies to this topic
#1 Hedgey
Hedgey
  • 179 posts
Posted 24 April 2018 - 10:28 AM
Hi guys,
I have a '78 Mini 1000 (built in '77) with the standard brake setup. Drums all round, black tag master cylinder, diagonal split, no servo and no pressure reducing valve.
As part of my resto i'm redoing the braking system to make it more effective/ safer while retaining the standard look of the car.
I will be installing 7.5" Calipers at the front with standard spaced drums at the rear.
I have bought a yellow tag master cylinder to replace the existing black tag as i always had troubles with trapped air.
I'm not intending on running a servo but may add one depending on how the pedal feels once the car is complete.
So my question is what brake line set up to go for? Front to Rear split? What size rear cylinders? Will the originals be okay to use? And will I need a pressure reducing valve?
I realise i'm asking a lot of questions but I want to get this set up right for obvious reasons.
Many thanks
Elliott
#2 SolarB
SolarB
  • 1,383 posts
Posted 24 April 2018 - 10:33 AM
The yellow tag has different size bores. Split must be front/rear.
I have the same setup, will try and find out what rear cylinder diameter I used.
#3 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 24 April 2018 - 11:23 AM
There's a page on the Somerford Minis site that explains the different rear cylinders, from memory you'll be able to easily work out what you need.
#4 Hedgey
Hedgey
  • 179 posts
Posted 24 April 2018 - 11:32 AM
Thanks for confirming the Front/ Rear split. Did you use a pressure reducing valve?
Thanks, just looking at the Somerford page and it has some good info
EDIT: I mean P.D.W.A. - Pressure Differential Warning Activator not pressure reducing valve
Edited by Hedgey, 24 April 2018 - 11:44 AM.
#5 Hedgey
Hedgey
  • 179 posts
Posted 24 April 2018 - 12:01 PM
Quick Update: I found this on Keith Calvers website, https://www.calverst...ias-adjustment/
Lots of great info and really clears things up
#6 nicklouse
  • 17,935 posts
Posted 24 April 2018 - 12:09 PM
every set up and parts are listed on Minispares site as well.
http://www.minispare...rt.aspx?1~9~105
#7 johnR
johnR
  • 2,244 posts
Posted 24 April 2018 - 12:53 PM
It would be interesting to have a comparison of the braking force each system provides - presumably BMC/Leyland/rover must have produced figures at some point? Of course there's no substitute for forward observation and treating all other road users as idiots!
#8 Hedgey
Hedgey
  • 179 posts
Posted 24 April 2018 - 03:00 PM
The Minispares and Somerfords lists are good but none of the setups listed exactly match the setup I will be using. Hence me asking for advice...
#9 carbon
carbon
  • 2,590 posts
Posted 24 April 2018 - 06:16 PM
IMO one of the best non-servo 7.5 inch disc set-up for road use is single line, 5/8 bore master cylinder, 5/8 bore rear cylinders and rear brake pressure regulator set at about 240psi to prevent lock-up of rear brakes under heavy braking on wet roads.
This is what I use with standard S calipers on the front, and have tried this using both silicone and standard type brake fluid. The main advantage I have found with silicone fluid is the rear cylinders don't seize up, but a downside is the silicone fluid costs more than standard type.
Also tagged with one or more of these keywords: brakes
