Just reassembled my gearleaver assembly and noticed that if I put the gear stick center according to the white ball on the base of the gear leaver it leans over toward the driver says the file is to big when I try and upload a photo
Bent Or Did I Just Not Notice?
minimotion
, Apr 24 2018 08:53 PM
4 replies to this topic
Posted 24 April 2018 - 08:53 PM
Posted 24 April 2018 - 09:02 PM
This might help
Posted 24 April 2018 - 09:18 PM
My initial thought was -you messed up on the assembly BIG time.... then i checked a spare unit & it's exactly the same.
So unless we've both bent them to the same position & the same angle it's how they're meant to be. Doesn't show up as looking odd when it's fitted in the car.
Posted 26 April 2018 - 11:10 AM
Was a bit wary of the title of this thread
Are you sure your ball is well greased and inserted correctly?
Posted 27 April 2018 - 07:33 PM
Looks to be 90 degrees out to me. The is towards the rear.
