These are so small the head of the gun doesn't fit in the rivet .. how have people managed to get these in properly? .. thanks
Mk2 Cooper Door Trim Rivets
Posted 25 April 2018 - 08:43 AM
Posted 25 April 2018 - 10:13 AM
I have used a small stainless steel rive- nut as a spacer over the rivet pin,
will try and cobble a picture together later if you need it!
Posted 25 April 2018 - 10:18 AM
yes please that would be useful
Posted 25 April 2018 - 12:29 PM
Posted 25 April 2018 - 02:38 PM
Stick the rivet in the hole, place some very small washers on the rive pin and put the gun on and squeeze, then pull the washers off. job done.
Posted 25 April 2018 - 06:59 PM
Make sure the rivets are the correct size before fitting! Some of the aftermarket rivets will not fit original door trim's as they are sized for the aftermarket trim's
Posted 26 April 2018 - 09:01 AM
I've got some of these trims to fit to my doors but am nervous about doing it. Presumably you fix the rivets and brass retainers then the trim should push onto them?
Posted 27 April 2018 - 05:56 AM
Posted 27 April 2018 - 01:26 PM
That way the propensity to rust around the rivets no longer exists.
Posted 27 April 2018 - 01:30 PM
Sounds like a good method which removes the possibility of poor fit due to mislocating the rivets as well
Posted 27 April 2018 - 01:33 PM
Posted 27 April 2018 - 02:26 PM
Posted 27 April 2018 - 03:00 PM
I now use Tiger Seal on the panel closing trip strips instead of those rust-generating steel clips. Just about to fit new ones on the front of the 'S'. I paint inside the channel with Hammerite, spray the outside surfaces, then just use Tiger Seal, clamp the strips on overnight and clean back the residue of the Tiger Seal with a plastic knife (I knew that airline supplied cutlery would be useful for something). You don't need to use excessive adhesive, just enough to hold the strip and to keep the rust out.
With rust such an issue, it makes sense to reduce the possibility of it developing in the future whenever you can.
Posted 28 April 2018 - 08:37 AM
