Here we go. This was just before i installed the flywheel puller
Best Answer Wiggy , 02 May 2018 - 04:30 PM
She runs!!! It was blocked injectors! I'm over the moon! Thank you so much for the help.
I had an mpi in recently for non starting, got fuel to the rail but not out of the injectors diagnostics shown a pulse signal from ecu to the injectors, tested them and they where clicking but no amount of cleaning would get them to perform put two working used injectors in and she fired up immediately
My injectors were the same. Just clicking, no flow at all. The Redex didn't do much; so I got a small syringe of Unleaded, stuck it in the top, and squeezed the plunger moderately hard. Then the missus pulsed the injectors a few times with some wire and a car battery. After a few tries they squirted like a good'un!
Go to the full postPosted 25 April 2018 - 04:51 PM
Posted 25 April 2018 - 04:55 PM
Posted 25 April 2018 - 05:05 PM
Mine looked like that when I installed it recently - the tabs on the locking washer didn't line up with the slots on mine either, I just punched new sections out to lock it?
Posted 25 April 2018 - 05:12 PM
I've just compared your photo to the one i have of my engine as i took it apart. They're both the same, so looks like your alignment is fine. Not entirely sure what Nick is seeing wrong...
Capture.JPG 30.25K 5 downloads
i am just not liking how this looks.
Posted 25 April 2018 - 05:15 PM
The key does look a little mashed. But it maybe the quality of the photo. Also, i hope he lifted the tabs after.
Posted 25 April 2018 - 05:16 PM
I'm inclined to agree with you there. It just didn't occur to me! Blast.
Oh well. You live and learn. Looks like I'll have to take the Wok off.
Posted 25 April 2018 - 05:17 PM
Yeah, that was pre torquing the bolt and staking the washer.
Posted 25 April 2018 - 05:18 PM
Posted 25 April 2018 - 05:26 PM
I agree the nut isn't locked in this picture - I'm not sure how the sections of the lockwasher with the small slot either side which I presume was designed to be bent out through the slots shown to lock it are supposed to line up? Taking the clutch/flywheel off and putting it back on 180 deg the other way wont change the alignment of those tabs which is what I presume you're looking at?
they dont you just bash the metal down. my issue is how the Key washer looks.
Posted 25 April 2018 - 05:30 PM
Also look at steves picture and how far down the lock washer is.
it is a few mm further past the chamfer on the clutch center nose than Wiggys as that is on the chamfer.
Posted 25 April 2018 - 06:26 PM
Well it wasn't tightened when the pic was taken, but I do agree that it seems a bit off.
I shall report back on the verdict of 'Is Wiggy an idiot?' once I've got the wok off. Thanks all.
Posted 25 April 2018 - 06:40 PM
Posted 25 April 2018 - 06:48 PM
ah then it may be ok.
Posted 25 April 2018 - 06:54 PM
I agree as long as it was torqued and locked
Posted 25 April 2018 - 07:15 PM
