Hi All,
My Mini failed the MOT on the rear brakes. I have replaced the rear drums as they were very worn and also shoes and springs, I have discs on front which are fine.
Went to bleed them, plenty of new brake fluid, starting at the back furtherest away, locked up the adjusters on rears as I was advised, I just can't get the rear brakes to bleed with out air bubbles, I've done the car multiple times, just get loads of air through. Can't see any leaks. The fronts seem fine, no air in fluid, it is just the rears.
Any things I should be looking for?
Thanks in advance.
