I'm replacing an old skool RVI taco with a new CAI RVC tacho.
The old one worked on an inductive loop and I inserted the loop between coil white wire and fuse box right next to the fuse box.
The new one works on a single sense wire
The CAI instructions say that I need to take a supply from the coil(presumably the + side of coil). Can I just plug the sense wire onto the fuse box terminal that the coil + white wire hits??
The car is a mark one mini cooper with the two-fuse box and has been converted to negative earth.
Cheers Guy
Cai Smiths Rvc Tacho... Csi 123
guywilko
, Apr 26 2018 09:24 PM
2 replies to this topic
Posted 26 April 2018 - 09:24 PM
Posted 27 April 2018 - 06:43 AM
You can take the +12v from the fuse box.
The 'sense' wire or -12V (white with black tracer) will need to come from the coil -ve (or CB) terminal.
Posted 28 April 2018 - 09:10 AM
So 100% the sense deffo has to be from the negative / ouput coil contact??
Damn.
Just built the loom onto the white......
Damn.
