So better late than never? When I first started my apprenticeship in a workshop we had a few minis come into the garage for small things, welding and whatnot. I instantly fell in love and that was me hooked, every lunchtime trawling through ebay on the MOT computers for my first car. In the end I found F455. The previous owner did some track days and hill climbs to my knowledge, before removing his souped up engine so a nipper like me could insure it. So what does a young naive boy do? Buy it instantly and it was the best choice I've made! So far its taught me more than anybody could, Ive rewired it, rebuilt the engine (badly as the sump-bung sill leaks) and sanded it back to bare metal and started the paint from there.
So already on it was
- Spax coilovers on a rear beam axel and spax shocks upfront
- reduced length trumpets to lower the front 10mm
- adjustable tie bars and bottom arms
- adjustable caster and camber plates at rear
- Braided lines
- 12" Minilites with Yokohama a0048 fitted
maniflow exhaust
Thats great but when I first bought it I had no idea what any of it meant, just sounded like stuff I shouldnt tell my mum..
SAM_1621 by Thomas Barrett, on Flickr
SAM_1626 by Thomas Barrett, on Flickr
I mean I was dead happy with it, but it wasn't what I wanted, I was young and dumb and wanted low
So with no goal in mind I thought I might as well strip her apart and learn about rebuilding engines, so I did! took apart a working engine, in hindsight I probably should but its given me some skills and finess when Im at work, honing cylinders and that.
SAM_2058 by Thomas Barrett, on Flickr
Pitting was pretty bad, nothing copious amouts of silicone cannot fix though
SAM_2542 by Thomas Barrett, on Flickr
After I finished honing, skimming and polishing and it was together I was given some 1.5.1 rockers - someone explain to a moron what the numbers mean, im yet to go into depth on engine modification as life has gone in the welding and fabrication side over rebuilds..
When the engine was back in (I painted the bay black in the end, hides all of the oil stains from the badly rebuild engine! ) I wrapped the exhaust, it seemed like the think to do as the carb was above it sucking hot air
17016178_1589586917722689_475415536_o by Thomas Barrett, on Flickr
And that concludes its for the beginning, lost loads of photos but jump forward after rewiring the car, learning about electrics in the process I thought that a switch panel was the way to go, I got arsey about putting the gauge bracket back in so I welded some tabs into the bulk head that did the trick, got everything fitted and set about making a panel.
18519145_1683408668340513_420073763_o by Thomas Barrett, on Flickr
18553693_1683431515004895_1579350504_o by Thomas Barrett, on Flickr
18617994_1689814521033261_655149953_o by Thomas Barrett, on Flickr
18765091_1698097423538304_1798591906_o by Thomas Barrett, on Flickr
Cool. Then as you do I went from interior to wheel arches, in that time the car when to bare metal and primered. badly.
SAM_2363 by Thomas Barrett, on Flickr
SAM_4070 by Thomas Barrett, on Flickr
WhatsApp Image 2018-01-14 at 15.35.34 by Thomas Barrett, on Flickr
So these were the ones, I think theyre the group 1's? Someone correct me but theyre dope and us loves them!
The old grill I removed was pretty cool but in the end I though honeycomb or get out so I bought a sheet of it from amazon, make the templates and mocked up my grill, I didnt like the chrome outer grill surround so I bought a mk1 moustache at a show, sanded it back, cut and folded the edges in a tiny bit and painted it black, then welded tabs and 10mm bolts in the inside to fix it to the car, I lost the photos but theres some at the end, promise!
20563031_1778270548854324_318053128_n by Thomas Barrett, on Flickr
WhatsApp Image 2018-04-26 at 22.34.18 (4)
Before the paint started going on I needed a glove box, Ive already made the panel, the brackets, the bottom switch pannel so may as well do this... glove box... g l o v e b o x..... b o x..... 5 0... I got it! Lets use a 50bmg ammo tin!
30226387_2054057247942318_635944309891268608_o by Thomas Barrett, on Flickr
With it all ground back it started to take the shape!
30127342_2054059594608750_8930130344401698816_o by Thomas Barrett, on Flickr
And thats the jump, sketchy history part. Sorry if it was confusing, but back to real time, currunt news!
So I was choosing a colour and in the end I went for windjammer blue, its a landrover colour and stood out, not many minis about with it on. I was going to go gunmetal grey but everyone and their mums has that colour on cars...
WhatsApp Image 2018-04-26 at 22.34.54 by Thomas Barrett, on Flickr
While I was waiting fro the paint to get through I primed the car for the last time
WhatsApp Image 2018-04-26 at 22.34.20 (3) by Thomas Barrett, on Flickr
And pinched some black paint and resprayed the roof
WhatsApp Image 2018-04-26 at 22.34.20 (5) by Thomas Barrett, on Flickr
Came out O K if you're at a distance!!
Then the paint came through, I was so excited and it was a scorcher of a day I came from work, ran home and rolled the car out, smashed the first two coats in the evening!
WhatsApp Image 2018-04-25 at 21.05.25 (2) by Thomas Barrett, on Flickr
WhatsApp Image 2018-04-26 at 22.34.20 (2) by Thomas Barrett, on Flickr
Then the next morning took the roof masking off
WhatsApp Image 2018-04-26 at 22.34.19 (1) by Thomas Barrett, on Flickr
She looked mean, looked dangerous and every time I look at her I'm glad that I own it
WhatsApp Image 2018-04-26 at 22.34.18 (2) by Thomas Barrett, on Flickr
ENOUGH MESSING ABOUT!
Lets get them arches on, arches are fitted and I ran some silicone to have a transition from the body - pre silicone pictures
WhatsApp Image 2018-04-26 at 22.34.17 (2) by Thomas Barrett, on Flickr
WhatsApp Image 2018-04-26 at 22.34.16 (6) by Thomas Barrett, on Flickr
Looks spot on in my vision.. time to start throwing it back together, heres the home made grill combo with the lights, Ill take a full shot of it soon.. this topic was unplanned but if I get it done I can have recent updates with better picture, fingers crossed...
WhatsApp Image 2018-04-26 at 22.34.16 (2) by Thomas Barrett, on Flickr
And I also got the rear lights fitted, I painted these black too and dish washed the lenses
WhatsApp Image 2018-04-26 at 22.34.15 by Thomas Barrett, on Flickr
So thats it, got the door glass fitted and handles but nothing to scream about, did the home made head liner last night and doing carpet today, everyday this car is getting more ghetto
I hope this wasn't too hard to follow, its across a pass of 3 years and I lost a lot of the memories and photos but time to play catch up and follow the building going back together, I know its not original but what is a original mini these days and I guess you could call all these mods period correct because Its all home made! much love x
Ill get better photos now, take the camera out with me
