Help And Advice Needed
electrical
1 reply to this topic
#1 kez301
kez301
    Starting My Mini Up
  • 4 posts
Posted 28 April 2018 - 04:58 PM
I have a 1992 Mini Sprite, when i bought it it was just a bare shell and over the last 4 years i have steadily been rebuilding it, i have now come to a halt due to 2 reasons, 1, i have no left hand sidelights, although both bulbs are good, i have gone back to the connections under the front panel and i have no power coming in there, likewise i have gone back to the rear loom joint at the bulkhead and again no power there so is there anywhere else i can look,
2ndly
   i have just replaced the flasher unit , (it is a combined flasher and hazard unit) and only have hazard warning lights working , can anyone please advise where to look next , the brake lights and heated screen are working so unlikely to be a fuse
thanks in anticipation
Kez
#2 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 28 April 2018 - 05:11 PM
Do you have half a dozen or so in line fuse holders behind the air filter I believe one of these is for your lights. Regards hazards/indicators do you have two relays under the bonnet on the off side inner wing if so the back one is for the headlights and the front one is for the indicators or at least it is on mine which Is a 93 injection. Good luck someone else may have more information.
