Mk1 Boot Conversion Panel
Posted 30 April 2018 - 03:23 PM
My Mini is looking solid at the moment, and I wanted to weld something. So I decided to convert an old mk3 bootlid to the earlier mk1/2 style to keep me busy with the welder!
I know this has been done on the forum before but I wanted to make a post.
Ive been teaching myself how to weld/paint etc so its not perfect but thats why Im doing little projects like this;
I bought this bootlid on facebook locally for £20, good price I thought! Especially with the Mk2 badge.
FB1F647D-4033-45D1-B894-2B2C5C9A146E.jpeg 66.78K 1 downloads
First thing to do was strip the it all down and weld the holes I wouldnt need anymore.
8E9C003A-6B9A-4256-81D0-724453C77BCE.jpeg 68.1K 3 downloads
24A8006D-7232-4FC6-B97D-6478C9150DDA.jpeg 44.4K 1 downloads
D2EE81A3-98FA-4982-AF9F-7102EBE5F4AB.jpeg 54.18K 5 downloads
Next was to mark out and cut the lower section ready for the new panel, as far as I remember there were 2 spotwelds that need to be drilled/ground out.
CFF95DD1-BF26-4872-B98C-4DEBB0E4A216.jpeg 61.61K 6 downloads
00F307FE-4F22-4315-BB5A-ECFB65F45562.jpeg 69.31K 4 downloads
69C75F58-21BD-41CD-A0EF-8624A06658D2.jpeg 69.04K 7 downloads
632F40C3-FEE7-4E7B-A580-E597FACEFC89.jpeg 63.13K 3 downloads
I cleaned up any rust, treated and painted with weld through primer. I clamped down the new panel and tacked down. Throughout the welding I took my time to prevent distortion as much as possible.
783EE9BA-49BA-4F78-9ED1-DD67BA948E9D.jpeg 57.85K 4 downloads
71829627-6826-4F33-A53C-0A26C625CFE7.jpeg 64.42K 9 downloads
4462001B-A864-49AA-AB43-E7E7924A6B8C.jpeg 60.83K 8 downloads
I used plenty of sealant in the back to keep the water out before folding it over.
8E2B348C-1C2B-4E53-AE6B-FD6122109710.jpeg 64.72K 4 downloads
All ground down, the GB badge is bolted on so those 4 holes had to be welded before moving on.
68EA2C10-F5C4-4A42-9B0C-F4BBC1E653E6.jpeg 41.29K 3 downloads
D062AD43-6978-45CB-A212-4BAB8F553907.jpeg 71.77K 2 downloads
Had to test it with the numberplate and badge! 😂
4F91FAB2-9533-4239-A1C6-B04C8FC074BD.jpeg 64.59K 3 downloads
Now to (try to) make it smooth!
5476A19F-55B7-4C27-ABB3-4B3C8B139B80.jpeg 73.15K 1 downloads
E48EA89E-68F3-4A35-AF40-C2FB1BB01BF6.jpeg 69.86K 1 downloads
C26A1962-594A-4797-A2AB-05A8DEBD99EA.jpeg 44.74K 1 downloads
A45FD8EE-9D3C-44B9-B675-07E3ED4130B6.jpeg 69.46K 3 downloads
Posted 19 November 2019 - 02:10 AM
My question is: how have you attached the plinth to the bootlid? And how did you then attach the number plate to the plinth?
Many thanks
Mark.
Posted 19 November 2019 - 02:30 AM
The number plate just gets drilled and bolted to the backing where ever the bolts sit well.
These are the hinge pieces.
http://www.minispare...66.aspx|Back to
This is backing panel/plinth.
Posted 19 November 2019 - 11:09 AM
I'm intending to do the same conversion to an '86 Mini ... looking at the photo that shows the exposed boot frame, it would appear that the open frame has not changed since the Mk1/2 boot and there still appears to be a recess in the frame for the number plate light. Is it therefore possible to fit a full Mk1/2 boot skin rather than messing about trying to marry up the conversion panel?
Posted 19 November 2019 - 12:34 PM
Posted 19 November 2019 - 02:30 PM
It's the aluminium version I was thinking but stock does seem to be an issue!
