Constipated Water Pump 🤔
3 replies to this topic
#1 charliefarlie37
charliefarlie37
  • 93 posts
Posted 06 May 2018 - 10:53 PM
Hi
I think my water pump is a bit corroded up ,got a new pump to fit, but what's best for flushing the block through? Cheers Attached File  20180506_234949.jpg   38.39K   0 downloads
#2 Rorf
Rorf
  • 370 posts
Posted 07 May 2018 - 05:49 AM
Wow that is the worst I have seen. Obviously sea water has been used as coolant :goaway:
That is why I am so anal about using good coolants and changing it every 3 years, like wise with the hydraulic brake systems
I don't think flushing will help much for the block, it will need some heavy chemical cleaning.
Edited by Rorf, 07 May 2018 - 05:51 AM.
#3 Dusky
Dusky
  • 4,715 posts
Posted 07 May 2018 - 07:40 AM
Put the old pump back on with a gasket and fill the engine with vinegar, or even better phosphoric or citric acid
#4 charliefarlie37
charliefarlie37
  • 93 posts
Posted 07 May 2018 - 12:16 PM
That's what you get for standing over 7 years, antifreeze was expensive stuff that came from my work.
Will caustic soda damage the head gasket?
Mini Spares
