hey all! i'm very new towards the Classic mini world and i have manual rover mini with airbag. currently, whenever i'm cruising and if i were to step on the brake too sudden, the RPM will drop ridiculously low and stall. did check the vacuum hose and no leak or whatsoever.
i know it has something to do with the adjustment in the fuel injector but may someone tell me what am i suppose to actually adjust?
i've brought my another mini ( which has similar problem) to a mechanic and what he did was remove the fuel injector cover, and told me a certain pin was not moving into place which result in the car not able to resume its RPM or something.
would appreciate if someone can guide me along the way!!cheers!
