Hi Newbie to the forum here and help needed desperately to try and get my Mini Mayfair moving.
Problem started when I stopped the car for a short period got back in and it would not start again.
Since then it has developed to the point where it would only start if I use easy start to start it. But even that now does not work. Since then has had new (second hand) SPI fuel ignition, new spark plugs, new coil and new CAT convertor as at one point it was spluttering and jumping. Was running ok after that once I got it started.
Garage has had it for weeks cannot work out what is wrong as always starts perfectly and drives fine when there which is so annoying.
Desperate now that the fine weather is here to get it going again as is a lovely little drive when it goes! Any advice much appreciated.
