When I brake I get a vibration through the brake pedal and the steering column. If I brake hard I get the vibration when I start to brake but it stops if I keep the pressure on. I suspect the pads because I have replaced them recently but I didn't the vibration until a couple of weeks later. The tie rod and bottom arm rubbers look good, but I will replace them anyway and I will change the pads and probably the disks as well but I would welcome any other suggestions before I go shopping.
Joe
