Manx Crankshaft.
21 replies to this topic
#1 DeadSquare
DeadSquare
  • 2,767 posts
Posted 08 May 2018 - 07:24 PM
At various times, people have balanced Ford engines on top of Mini Gearboxes, presumably using the diva and drop gears.
For 50 years, just for the hell of it, I have wanted to put a 948cc diesel A series engine in my mini pick-up.
Does anyone know of anyone who can weld a "tail" on my crank and machine it for me?
#2 whistler
whistler
  • 1,706 posts
Posted 08 May 2018 - 07:38 PM
Don't know about bearing sizes but the 998cc petrol engine has the same stroke. Could you not use that crank?
#3 DeadSquare
DeadSquare
  • 2,767 posts
Posted 08 May 2018 - 07:52 PM
2" mains, 1.75" big ends, and the nose is longer to drive the injector pump.
#4 Spider
  • 13,935 posts
Posted 08 May 2018 - 08:48 PM
I like your project and am looking on with some interest, though, I tend to think you'd really be up for a billet crank.
#5 Mini Manannán
Mini Manannán
  • 2,825 posts
  • Local Club: man Estate
Posted 08 May 2018 - 10:05 PM
Why Manx crankshaft?  I'm from Manxland and am confused...
#6 nicklouse
  • 17,945 posts
Posted 08 May 2018 - 10:17 PM
Manx Racing no longer about.
some reading about ford powered Minis
https://www.pistonhe...90&t=761453&i=0
#7 stoneface
stoneface
  • 313 posts
I guess it's to do with Manx Racing that made a Ford to Mini gearbox crank conversion.
The option was either a billet crank ot a bolt on extension to convert the Ford crank to take the Mini clutch and flywheel.
Peraonally I wouldn't trust a welded on extension.
#8 DeadSquare
DeadSquare
  • 2,767 posts
Posted 08 May 2018 - 10:38 PM
Manx cats don't have a "tail", and neither does my crank.
#9 Vegard
Vegard
  • 15 posts
Posted 15 December 2018 - 12:20 AM
Find a Midget 1098 block, (2”’mains) and fit a 1071 crankshaft. This is a BULLET proof “small bore” engine. Albeit not the cheapest.
#10 Cooperman
  • 23,039 posts
Posted 15 December 2018 - 12:49 AM
Would it not be easier to use a Mini engine & gearbox, with the diesel pistons and head together with the diesel injection system, diesel cam and diesel manifolds?
#11 DeadSquare
DeadSquare
  • 2,767 posts
Posted 15 December 2018 - 10:29 AM
The diesel pistons are 850 bore and 998 stroke, but the 998 crank won't fit an 850 block.
I have been looking for a midget block for many years.
#12 mini13
mini13
  • 3,805 posts
Posted 15 December 2018 - 10:58 AM
What do the pistons look like, I think the cheapest way would be to try to use some other production pistons, or even get them made, maybe in 1275 and use a SA 1100 crank.
For the injection pump, it should be prety simple to get somekind of keyed adaptor made up, also I thought of was the cam that was extended for the pump.
#13 GraemeC
GraemeC
  • 7,315 posts
Posted 15 December 2018 - 11:38 AM
Liner a 998 block down to 850 bore size?
#14 mini13
mini13
  • 3,805 posts
Posted 15 December 2018 - 11:55 AM
Good call on the linering, also whatever you do really deserves a turbo on it to get some useful oomph out if it.
Maybe stick it on an auto box too just for extra amusement!
#15 DeadSquare
DeadSquare
  • 2,767 posts
Posted 15 December 2018 - 12:33 PM
I looked into using 1100 block, crank etc: many years ago and having pistons made  ( now, of course, it would be would be 1300 ),   but I think the lowest price that I cold get them down to was the same as twenty sets;
Also, the "nose" on the crank is an inch longer, with another key, for the drive to the injectors.
We are not talking about a lot of horsepower, even turbocharged, so if a bolt on tail will take SCA or twin cam Cortina power, a good welder ought to be able ti stick a tail on.
I wonder if Gorilla glue would do it?
